Variography of composite Ag, of all coded veins (1–33)
showing the pair of axes with orientation at 90° and 0°,
with an approximate range of 80 meters.
In Figure 14 and Figure 15, composite Au variography
for all veins (1–33). The variography is shown in the ori-
entation at 90° and 0° with a range of 40 to 45 m. It was
evaluated in the MEDS 350° -0°- 90 plane.
Variogram Modeling
Resource Classification
For resource classification, the parameters of minimum dis-
tance from the compound to the block (DIST field) and
number of drillholes involved in delivering grades to a block
(NMUE field) were taken into account. These parameters
are evaluated and the result is recorded in the “CATEG”
name field of the block model, and will be used to classify
the resource type.
Measured Resources will take 2/3 of the range up to
40 m, Indicated Resources will take the last third of the
range (from 40 to 60 m). Finally, the areas between the
drill holes within the mineralized zone and restricted by the
solids of each vein will be considered Inferred Resources.
Figure 13. The variogram for all veins with Azimuth on
Plane 90°-Range of 80 meters
Figure 14. The variogram for all veins (Au) with Azimuth on
Plane 0° -Range of 40 to 45 meters
Figure 15. The variogram for all veins (Au) with Azimuth on
Plane 90° -Range of 40 to 45 meters
Table 5. NNW System, elements for modeling of variogram
Element Ag Au
Variogram Type spherical spherical
Nugget 0.55 0.65
Sill Total 1 1
C1 0.25 0.20
Major Axis Range 1 25 30
Minor Axis Range 1 30 25
Vertical Range 1 25 30
C2 0.20 0.15
Major Axis Range 2 60 45
Minor Axis Range 2 30 30
Vertical Range 2 25 30
Axis Rotation: Plane Vein
Type of Rotation MEDS MEDS
ROT 80 80
DIPN -90 -90
DIPE 0 0
Table 6. The criteria followed to categorize resources in this
work
Distance
N° of
Drillholes
Field
CATEG
Category:
Resource
0–40 ≥3 1 Measured
0–40 ≥2 2 Indicated
40–60 ≥2 2 Indicated
60 1 3 Inferred
