Geochemistry Analysis
Geochemical analysis was done by the USGS. Figure 8
shows a chondrite-normalized REE plot of samples from
Copper Flat and Carlisle-Center mines. The results show
light REE enrichment of up to 200 times chondritic values
at Hillsboro, however thisit is not attractive for economic
recovery. Hillsboro samples have higher light REE enrich-
ment as compared to Steeple Rock samples.
Figure 8. A chondrite-normalized REE plot (McDonough
and Sun, 1995) of samples from Copper Flat (in blue) mine
and Carlisle-Center (in orange)
Endowment
Mineral endowment generally refers to the quantity of
minerals present in a specific region irrespective of whether
it has been discovered or not (Davis et al, 2020). We com-
puted for critical minerals (i.e., Bi, Co, Cu, Ga, Te, Zn, Zr)
endowment in kilograms for the tailings at Copper Flat
mine with a volume of approximately 518753 m3 and an
assumed bulk density of 1430 kg/m3. The minimum, maxi-
mum, and mean endowment was then obtained by multi-
plying the minimum, maximum, and mean concentrations
of these critical minerals by the mass of tailings. See the
results in Table 2. It is also important to note that these
endowment values only help us to understand the potential
availability of these minerals and do not necessarily mean a
measure of resources or reserves.
PRELIMINARY CONCLUSIONS
The S present in samples from Carlisle-Center mines are
mostly acid forming and can potentially cause acid mine
drainage which can dissolve other minerals. Samples from
Copper Flat that are nonacid forming may be used as back
fill material.
Most of the waste rock pile at Copper Flat is charac-
terized by mostly relatively coarse sand fraction, which is
cohesionless, however the presence of calcite and gypsum
provides a cementing bond, which may improve slope sta-
bility. Further geotechnical analysis is recommended to
understand the slope stability conditions better.
Future work would be focused on analyzing geochem-
istry of different particle fractions to ascertain any existing
correlation between mineralogy and particle size. Also, bulk
density test should be conducted to compute for the mass
of mine waste piles
and thus estimate the critical mineral endowment of
the studied mine waste areas.
Table 2. Critical mineral endowment
Endowment (kg) Min Max Mean
Bi 964 1,706 1,276
Co 4,228 7,937 6,880
Cu 256,669 574,166 402,918
Ga 13,353 15,578 14,243
Te 178 363 302
Zn 28,931 53,411 44,027
Zr 174,327 210,676 194,393
Table 1. District’s mineralogy
Location Mineralogy
Copper Flat Mine,
Hillsboro
These samples consist of mostly
rock forming minerals (i.e., quartz,
K feldspar, albite, and some micas/
muscovite). They also include clay
minerals commonly seen are the OH
clays (e.g quintinite and hydrotalcite),
altlered micas (eg.illites) and
smectitites. Alunite is present, which is
an indicative of acidic precipitation of
SO4 and calcite which was present
in samples from tailings.
Carlisle- Center,
Steeple Rock
Most samples were mostly quartz
and minor micas. The slighlty darker
samples were rich in Mn oxides.
Another interesting mineral found
in some of the samples which were
typically yellowish in color was
beaverite which is a
Pb-Fe-Cu sulfate.
