modeling, fault detection, and process control. Their study
emphasized the importance of supervised and unsupervised
learning methods for enhancing recovery rates and reduc-
ing variability in mineral beneficiation (McCoy &Auret,
2019). However, their analysis highlighted the limited
application of these techniques in complex, multi-variable
environments like phosphate flotation. This limitation
sets the stage for further exploration in more specialized
contexts.
Ali et al. (2018) explored the use of random forest (RF)
and adaptive neuro-fuzzy inference systems to model and
optimize the flotation behavior of fine high-ash coal. They
demonstrated that ML models could capture complex non-
linear relationships between input parameters (e.g., reagent
dosage, pulp density) and output performance metrics (e.g.,
recovery rates, concentration grade). While insightful, their
study focused primarily on coal, leaving a gap in applying
similar techniques to phosphate flotation.
Froth image analysis, an area of increasing importance,
was explored by Galas and Litwin, who employed convo-
lutional neural networks (CNNs) to monitor and control
froth stability. Their work showed that real-time froth imag-
ing could significantly enhance process adjustments, reduc-
ing human error in interpreting froth behavior. However,
the study did not extend to integrating these insights with
predictive models for closed-loop control, highlighting
another area for advancement.
Nasiri et al. (2024) developed physics-informed ML
models that merged first-principles with data-driven meth-
odologies. This hybrid approach addressed limitations of
purely data-driven models by incorporating domain knowl-
edge, enhancing generalization across varying operational
conditions. While promising, their application was pri-
marily in base metal flotation, not directly addressing the
specific operational dynamics of phosphate flotation. This
work underscores the need for domain-specific adaptations
of such hybrid models.
The role of reagents in flotation, particularly in phos-
phate beneficiation, was investigated by Alsafasfeh et al.,
who used polymeric depressants to enhance separation
efficiency. Combining experimental results with ML-based
optimization, they achieved notable improvements in both
grade and recovery. However, their study lacked real-time
optimization, which could further improve process adapt-
ability and responsiveness to operational changes.
Advancements in ensemble learning were explored by
Szmigiel et al., who applied deep learning for froth image
analysis. Their research demonstrated that ensemble models
like Random Forests and Boosting techniques could pro-
vide high-accuracy predictions, particularly for operational
adjustments in real-time environments. Similarly, Ortiz et
al. (2022), working within Metso: Outotec, utilized super-
vised learning models to enhance control systems in flo-
tation processes. This approach significantly increased the
effectiveness of process optimization, underscoring the
potential of ML to improve operational efficiency and opti-
mize resource recovery in the mining industry.
Gomez-Flores et al. (2022) advanced the application
of AI in mineral processing by deploying ML models to
predict flotation outcomes from both physicochemical
and operational perspectives. Their work demonstrated
how various AI techniques, including deep learning, could
effectively forecast grade and recovery rates, providing a
foundation for more informed and dynamic adjustments
in the flotation process. This approach significantly reduces
operational downtime and enhances recovery consis-
tency. However, the direct application of these AI strate-
gies in phosphate flotation, with its distinct characteristics,
remains insufficiently addressed, underscoring a crucial
area for further exploration.
Despite these advancements, phosphate flotation
remains underexplored in the context of real-time AI and
ML applications. Existing research primarily focuses on base
and precious metals, overlooking the specific challenges of
phosphate beneficiation, such as fine particle distribution,
complex reagent interactions, and fluctuating feed quality.
While image-based monitoring has advanced, its integra-
tion with predictive modeling for real-time closed-loop
control is still in its infancy.
Additionally, current predictive models often lack the
operational flexibility needed to handle the dynamic nature
of flotation systems. Few studies have explored the synergy
between ML models and domain-specific insights to opti-
mize key performance indicators such as P2O5 recovery and
reagent efficiency in phosphate flotation.
This paper aims to address these gaps by developing an
AI-driven predictive model specifically designed for phos-
phate flotation. Leveraging real-time operational data and
incorporating domain-specific expertise, the model seeks
to dynamically optimize key parameters, improving recov-
ery rates and operational efficiency while reducing reagent
costs. By integrating predictive modeling with real-time
monitoring, the proposed framework aims to bridge the gap
between static models and dynamic process control, offer-
ing a transformative approach to phosphate beneficiation.
METHODOLOGY
Our approach to integrating AI for optimizing critical flo-
tation parameters consists of two main phases: data prepa-
ration and model development. The data preparation phase
contexts.
METHODOLOGY
