(Nd) are the primary REEs present in the sample. The
purity of the feed sample obtained from EDX analysis was
55%.
Leaching Experiments
Leaching experiments were performed as a batch process
in a glass reactor that was mechanically stirred at 300 rpm.
The tests were carried out with a solid-to-liquid ratio of
0.1:10, ensuring that external mass transfer is not the rate-
controlling step. The temperatures at which the test was
carried out were 60 °C, 70°, 80°C and 90 °C. 2 mL of the
pregnant solution was withdrawn periodically, filtered,
diluted with nitric acid (5%), and submitted for ICP/MS
analysis. Table 1.5 shows the periodic interval at which the
Figure 3. Percentage Composition of Mineral of the REE Ore
Figure 4. XRD Graph showing peaks of the mineral composition of the Ore
Table 4. Elemental composition of feed Sample
Elm. O F Al Si K Ca Fe Y La Ce Pr Nd
Cont. %23.6 11.8 1.4 1.7 0.6 3.1 5.0 1.2 27.5 6.7 4.9 12.4
