which the AI can then process to extract key information
and populate databases. This application creates value by
improving the accuracy of incident reporting and analysis,
leading to better safety outcomes. Implementation is fea-
sible with the development of a user-friendly interface and
integration with existing health and safety systems.
How the Solution Could Work
An LLM-based hazard and incident reporting system
would allow employees to report potential hazards and
actual incidents directly through their existing two-way
radios. Utilizing voice-to-text technology, the system would
convert spoken reports into text, which the LLM would
then process.
The AI would be specifically trained to understand the
nuances of spoken language in the context of mining opera-
tions, including any jargon or shorthand used by the work-
ers. Once the report is transcribed, the LLM would identify
and extract key details such as the nature of the hazard or
incident, specific location, time, and any immediate actions
taken.
Value Provided
The integration of voice reporting via two-way radios would
encourage more proactive hazard reporting by making it
convenient for employees to report issues as soon as they
are identified, without needing to return to a workstation
or find a computer. This immediacy can lead to quicker
responses to potential hazards, reducing the likelihood of
incidents occurring.
For actual incidents, the system would ensure a rapid
and accurate capture of details, which is critical for emer-
gency response and subsequent analysis. The data collected
would provide insights into common risks and inform
strategies to prevent future occurrences.
Implementation Feasibility
Implementing this voice-enabled LLM system would
involve interfacing the AI with the radio communication
network and ensuring reliable voice-to-text conversion in
the noisy environment of mining operations. The system
would need to be robust enough to handle various accents
and speech patterns.
Training the LLM would require a dataset of voice
reports to fine tune its understanding of mining communi-
cation. While integrating voice reporting into the existing
safety management infrastructure presents additional tech-
nical challenges, the potential for significantly improved
hazard and incident reporting makes it a compelling option
for enhancing mine safety. The system’s design would focus
on user-friendliness to ensure widespread adoption and
effectiveness in promoting a culture of safety and vigilance.
Preventative maintenance
Overview
Predictive maintenance is crucial in mining. LLMs can be
used to process equipment logs and maintenance records,
predict when maintenance is required, and generate work
orders. This application is akin to the predictive analytics
used in finance for fraud detection.
The business value is in preventing equipment failure,
reducing downtime, and extending the life of expensive
machinery. Implementation is feasible with the integration
of LLMs into existing maintenance tracking systems.
An LLM-based solution for equipment maintenance in
mining would involve the AI analyzing historical and real-
time data from equipment logs and maintenance records.
The system would learn patterns associated with equipment
wear and failure, enabling it to predict when maintenance
should be performed before a breakdown occurs.
The LLM would be integrated with the mining com-
pany’s existing maintenance tracking systems, allowing it
to process data from various sources, including sensors on
the equipment, operator reports, and maintenance history.
Value Provided
The primary value of this predictive maintenance system
is the reduction of unplanned downtime, which can be
extremely costly in terms of lost production and emergency
repair expenses.
By accurately predicting maintenance needs, the sys-
tem ensures that equipment is serviced only when necessary,
optimizing maintenance schedules and resource allocation.
This not only extends the lifespan of the machinery but also
enhances operational efficiency and safety.
Additionally, the system can help identify training
opportunities for operators by highlighting recurring issues
related to equipment misuse.
The feasibility of implementing this LLM-based predictive
maintenance system depends on the availability and qual-
ity of data. The more comprehensive and clean the data,
the more accurate the predictions will be. Integrating the
LLM with existing maintenance software may require some
initial customization and investment in information tech-
nology (IT) infrastructure. However, once in place, the
then process.
taken.
Value Provided
Overview
Value Provided
repair expenses.
