iv
24-021 Corrosion Strategies at the Resolution
Copper Project, Arizona
24-022 Critical Minerals and Acid Mine
Drainage in Black Hawk Mine Waste, Grant
County, New Mexico
24-023 Demonstrating the Financial Impact
of Mining Injuries with the Updated Safety Pays
in Mining V2.0 Web Application
24-024 Designing a Rockfall Testing Program
for Open-Pit Mines to Investigate Runout and
Bench Catchment
24-025 Determination of Incombustible
Content with Portable Spectrometers Using
Chemometric Modelling: Preliminary Results
24-026 Development of a Comprehensive
Mine Plan Approach for the Extraction of Icy
Regolith on the South Pole of the Moon Using
Surface Mine Modelling Software
24-027 Processing Marcasite Copper Ore with
Iron Depressant, Hybrid Reagents, Advanced
Data Analytics, Visiofroth™ and Breakthrough
Expert Control of Entire Flotation Plant—
Fundamentally Transforming Doe Run Buick
Mill to Create Value and Expand Ore Resources
24-028 Dewatering over 8,000 tpd of Copper
Tailings at a Mine site in Peru with the Largest
Filter Press in the World: Case Study and
“Lessons Learned”
24-029 Digital One Enterprise Expert
Operating System on Production Line at Doe
Run’s Buick Mill—Expert-Control of Flotation,
Grinding and Things (EOT)
24-030 Efficiency of Carbon Sorbents
in Removing Zinc from Mine Water:
A Comparative Case Study of the
Rothschönberger Stolln Water
24-031 Engineering a Large Eco-Friendly
Reinforced Sloped MSE Wall System to Increase
the Size of a Flat, Work Area of a Mine
24-032 Enhancement of Ultrafine Phosphate
Flotation Using Eriez’ Cavtube Column
Flotation Technology
24-033 Enhancing Robotic Perception for
Autonomous Roof Bolting Using an Event Based
Machine Learning Framework
24-034 Enhancing Ventilation and
Development Planning in Underground Stone
Mines: Insights from a CFD-Based Study
24-035 Enrichment Feasibility of Tellurium,
Gold, and Silver from Copper Tailings
24-036 Estimating Air Blast Velocity Using
Optical Flow Algorithm
24-037 Examining Pull-Out Tests for Grouted
Rib Bolts: A Comprehensive Analysis
24-038 Experimental and Numerical Analysis
on Failure of Soil Slopes Induced by Increasing
Pore Water Pressure
24-039 Experimental Study on Position
Evolution and Load Transfer Law of Support in
Large Dip Angle Stope Based on Digital Twin
24-040 Explosion-Proof Enclosure Failure
to Contain a Lithium-Ion Battery Thermal
Runaway
24-041 Fleet Efficiency Evaluations for
Optimal Cycle Times Through Various Blast
Designs in the Sorted Geological Formation
Under Constrained Operating Conditions
24-042 Geochemistry of Critical Minerals
in Mine Wastes at Hillsboro and Steeple Rock
Districts, New Mexico
24-043 Geochemistry of Critical Minerals in
Mine Wastes in New Mexico
24-044 Geochronology and Critical Mineral
Potential of Selected Laramide Porphyry and
Related Deposits in Southwest New Mexico
24-045 Geology Says Otherwise
County, New Mexico
Bench Catchment
“Lessons Learned”
Pore Water Pressure
Runaway
